Bill,
Following the angle that Fran's chassis have from the bottom of the car, at the back of the frame, up to where the pivot point for the rear clip, you are going to be very close to the optimum angle for a diffuser. Hopefully the webpage that Dreamin' gave you will provide this optimum angle, which allows the air flow to remain laminar on the diffuser. What you probably should do to make this actually work is to put strakes (fences) on either side of this panel, the bottoms of which remain in line with the rest of the the bottom of the car. The picture of the Ford GT shows this pretty well; although, I don't think you'll need the channels to the sides (left two shown), just the inner most strake and, of course, its twin on the other side. From what I recall on Ron E's chassis, this panel is pretty much the same width all the way up. If it were to widen appreciably, you might want to put interior strakes in it so that air doesn't diverge outwards too rapidly as well (take a look at the diffusers on the ALMS or GrandAm Vettes to see what I mean.)
The idea is that, with the air remaining laminar to the diffuser (not breaking away and becoming turbulent) there is a speed gradient with the air near the ground going slower and the air nearer the diffuser going faster. This faster air causes a low pressure boundry (bernoulli's effect) along the diffuser, thus creating down force. Given the proximity of the engine bay to where the diffuser starts to angle upward, it is possible that louvers under the engine tray could cause the air to become turbulent and ruin the effect of the diffuser. (To be honest, none of this is likely to happen at the fastest speeds you'll be going on a highway; as mentioned, it would only be at very high speeds on a track when this would all come into play.) On top of this, you want to push as much air as possible out of the tail grills to fill in the turbulent air there from the spoiler (does the term "drafting" ring a bell.) The down force off of the spoiler comes at the cost of drag cause by this turbulence, so if you can fill this area with air from inside the rear clip, it will push the turbulence back away from the car and reduce drag. (I think this is one reason Mk IIs and the later Mk Is had larger grills in the back of the car. Of course, I could be wrong as I am speculating here.)
Lynn
