thanks hector! i spend the last month to find all matching parts. StealthEV in california will supply the motor, the batteries, charger and dc dc converter. i found the AC compressor and also power brake from tesla model S (works on 12V). i will however set all batt in the gas tank and engine compartment. There is a lot of room there and i need some weight at the back to ensure proper traction casue i m going for the p100D ludicrous motor (647hp/650 lbs-ft). i will eventually relocate the ac compressor in the front (to run shorter ac lines) but its only 8 kgs. i m currently waiting for the customs authorization to import (cause i live in qatar and they make it difficult here). i will update it as soon as i have newsI looked at that option quite a bit, lots of guys doing tesla conversions these days, there is a shop in California that sells the entire powertrain package, it is helpful to look at their setup and the battery packs they use depending on your focus i.e performance vs distance, another advantage is that you can place some of the battery packs upfront and achieve close to a 50/50 balance, will be very interesting following your progress, please keep us posted and good luck .
