I am going longitudinal and no there will be no stretch and i know the axle's will not be lined up but from what i have read i will be fine with anything under 25 degree's of angle and i think i will be at around 10 degree's
well i am going with a ZF 5hp19fl it should be fine for the stock abz and if i want i can upgrade it to handle more power level 10 makes parts for it or you can get a full blown transmission they claim is bullet proof check them out Audi Transmissions | Audi Torque Converter | Audi Valve Body
oh ya i wouldn't spend $5000 on any transmission but i will spend $500 plus another $500 to make it shift faster than even a normal standard transmission and sure it wont handle 2000 ft lbs of torque but if it handle 350 to 400 ft lbs of torque with Little more then boosting line pressure that is good enough for allot of engines mine included and is cheaper then a 01x or 01e
i have the 012 so i will stick with it they are cheap to buy kinda like a bic lighter lol but was wondering what blows up on them
Just wondering what fails first normally on the 012 transmission and how it compares to the 016 strength wise
Scott i noticed that they put the 012 in the early boxsters did the do anything to make them better for the boxster or are they just the same weak transmission and what is the 5 speed transmission that the 2.7 boxsters used from 2000 up
Scott what do you know about this transmission i like it due to the axle location being moved to just behind the bellhousing flange it makes it work better in the fiero
