Spent most of yesterday trying to bleed the cooling system.
Initially only one side of radiator became warm (the one with the bleed back to the header tank) Eventually by jacking the lt front side of the car up and then filling the rad via the engine bleed port on theengine return inlet housing got degree of circulation. Have put a thermostat switch in the circuit to turn the fans on and off at 90 degrees C .However the system seem to boil quite easily and the temp gauge reads 95-105 all the time.
Any advice on bleeding the system
And with the header tank at cold should there be any water in it as mine has emptied overnight or is that the air lock moving
Initially water prefered t o run round the bleed system rather than through the rad
