I'm working on a couple of projects at the same time. For the "other" one, it would help if I could flip the ring gear. Can that be done with an Audi 016?
Thanks in advance!
Al Keller
No. It uses a hypoid gear set which means that the pinion is not on the same centerline as the ring gear. You can only flip the gears on a spiral bevel set like used on Porsche transaxles, (G31, 901, 915, 930, G50) or VW air cooled Beetle or Bus.
