My intention, of course, is sincere constructive criticism /ubbthreads/images/graemlins/smile.gif, so I would like to say one thing about that A-arm mounting scheme. that bolt is going to be severely stressed. There are 2 major things that that bolt has to deal with. 1) the fact that it is a lower A-arm and the heavier loaded of the two arms, and 2) cyclical loading. If the rod-end stays in the position it is in the picture, it's probably OK. Personally, I would not drive it if the rod end were in the middle. I knew you weren't going to drive it with all that empty space and no washers! /ubbthreads/images/graemlins/blush.gif
I guess you are setting it up to have the rod-end in that position because you probably switched over from a rubber bushed arm to the rod-end style and designed it so the rod-end won't be in the middle of the bolt span. Just figured that out... duh /ubbthreads/images/graemlins/bash.gif
Nice looking a-arm though!
