The GT40s Forum has to be one of the best online forums anywhere.
CAV Canada is glad to help out on technical issues, performance parts and service. Although our focus has always been CAV GTs, many of our parts will fit or can be used on other cars. Gives you an opportunity to get away from heavy, sloppy or weak donor parts etc.
So for a limited time, forum members will enjoy a 10% discount off the CAV Canada Race Parts selection.
Shown below is our Four Corner Kit which includes 2) Steel Front Uprights, 2) Steel Rear Uprights, 2) Monoball Reversed Lower A-Arms and complete hardware (some parts like clevis pin shoulder/spacers not shown). Includes labour to fit your stub axles and new front axle torque nuts.
These parts are designed for the "Series 100" cars manufactured to the original CAV (Cape Advanced Vehicles) specifications. In other words, the Autofutura CAV GTs s/n 101 and up already have factory supplied upgraded parts so you're covered.
Fitting the Four Corner Kit will take all the binding out of the rear suspension, optimise suspension geometry to give more grip in acceleration, cornering and braking, not to mention improved ride, reduced steering effort, reduced bumpsteer and kick back in the steering wheel. That's what the parts were designed to do and customer feedback confirms it.
Another benift of the uprights is brake and wheel bearing cooling and reduced heat soak to the bearings too. There is more information about the parts in the CAV section.
So what's the deal you say?
2) Front Uprights regular price 1495.00 each
2) Rear Uprights regular price 1495.00 each
2) Rear A-Arms regular price 790.00 each
Set of 6 peices regular price 7560.00
GT40s Forum Discount 10% 756.00
Less 300.00 per core* credit 1200.00
net, pre shipping 5604.00
That's over 25% off in total with four rebuildable* cores! For non CAV applications that 10% off really helps (maybe spend a little of it on the better half)!
These are our most popular parts and several cars have been fitted with it. You can also get the forum discount on either end and the Rear A-Arms can be bought without the uprights for slightly more money (addiditional parts required).
