Randy Folsom Supporter Jan 19, 2026 #21 Unfortunately, I use Fusion 360 and don't have access to Solidworks.
D David mono Jan 19, 2026 #22 Randy Folsom said: Thank you so much. Click to expand... I downloaded the app eDrawings to look at the file.
Randy Folsom Supporter Jan 20, 2026 #23 David Deschamps said: I downloaded the app eDrawings to look at the file. Click to expand... I can see the file. Looks promising. Hoping someone will open in Solidworks and export/post as STEP.
D David mono Jan 20, 2026 #24 Randy Folsom said: I can see the file. Looks promising. Hoping someone will open in Solidworks and export/post as STEP. Click to expand... The roof is to wide in the narrow area compared to original. A export/post as STEP would be helpful.
T Ole Nylende Supporter Jan 20, 2026 #25 Revising this model "at the moment", it is alot of work. I believe the "base" model has been uploaded to grabcad. Attachments 1.JPG 213.4 KB · Views: 92
TSUART RINGWALD Supporter Jun 20, 2026 #26 Randy Folsom said: Unfortunately, I use Fusion 360 and don't have access to Solidworks. Click to expand... Sorry Randy, see attached saved as STEP. Attachments GT40-STEP ASSY-06202601.zip GT40-STEP ASSY-06202601.zip 6 MB · Views: 32
Randy Folsom Supporter Jun 20, 2026 #27 Stu GT340 said: Sorry Randy, see attached saved as STEP. Click to expand... Thx much for sharing. I was able to get fusion to thicken a few sections. I will work on this when I get back from Singapore.
Randy Folsom Supporter Jun 22, 2026 #28 Stu GT340 said: Sorry Randy, see attached saved as STEP. Click to expand... Stu, Would the process you used to convert to STEP work on an STL with zero thickness, i.e., a scan saved as an STL? Cheers, Randy
