I know its been posted on here and i have read the other threads etc however i had some more questions and thought easier to start a fresh one vs reopening an old one.
So my current dilemma:
I have a couple of options for blocks to base my build on (11:1 9.2 deck SVO block, basically a nascar esque build with 3.45" crank and 6.3" rods running small port, small chamber Yates C3 restrictor plate heads). The car will be 95% road use car but will be spun to 8k rpm when i feel like it and can put the power down.
-One is a rare siamese wet sump A351 block, at 4.060 with large amount of meat left in it but one sleeve. 2.749 cleveland mains. (pre 85 casting date)
-The other are non siamese G351 dry sump blocks (handful of options varying between 302 mains converted block with 55mm cam bores to 2.749 mains with normal or 55mm cam bores.
All blocks are either .040 or .060 over but sonic checked and good for boring to 0.080). (post '85 but pre '92 casting dates). 302 mains is preferable due to crank/rod options and less rotational friction and heat etc at higher rpm, but that block is 0.066 over fully machined ready to go.
Obviously i know dry sump is the best but it costs more however there are a lot of v good used dry sump systems that you can get for a good price.
So what i've costed below doesn't actually come up hugely different price wise.
Wet sump setup :
Pan - $350-450 w/ windage tray, crank scraper (if bought new)
Pickup - $80
Pump - $150 (precision pump)
Possibly oil cooler set up - $250?
Shafts and ARP bolts etc - $60
Accusump - $600
So say $1250-1500 if everything bought new.
External pump wet sump:
Pan - $450 (if bought new)
Pump - $3-400 (used)
Belts/Crank pulley/Pipework - $300 +/-
Accusump - $600
So say maybe $1600.
Dry Sump:
Can get 4 stage kits complete from race team etc for $600-$2000 with pan if they have a suitable one for 4 stage system with tank. Would only purchase non failed engine kits.
Naturally would have to go through, check the pump and fully clean everything etc so budget for that.
Would allow lower mounting of engine if possible (will be using either ZF/quaife or 930 porsche box) to compensate for taller deck and exhaust port height.
Obviously the dry sump is the best hands down and it will pull crankcase vacuum, its just big and complicated and would be a used system. . . . .
Naturally the decision affects which block i go for and they have their advantages and disadvantages for each one. Bit of an essay but hopefully you can see my dilemma of which direction to go in.
Would love to know your educated thoughts.
Wet sump setup :
Pickup - $80
Accusump - $600
Accusump - $600
So say maybe $1600.
Dry Sump:
