Engine mounts?
Need to buy some engine mounts but I'm not certain what I want to buy.
When I search people talk about engine mounts and also engine adapter plates for the LS.
I was given a part number for LS engine mounts - 10349965 (thanks Cam) - but it shows up as different years starting around 2005 (nothing before then?).
What exactly do I want to buy? OEM engine mounts for a, say, 2000 SS camaro (lS1)?
Terry Oxandale
Skinny Man
I've got the aluminum ones as well, but they are from a C5 and very simple. Some references use "stand" or "bracket", which is without the rubber mount (isolator) that bolts onto the aluminum piece.
The cast aluminum OEM mounts for an LS3 Corvette are all you need...
$400 per mount up here at the local stealerships :laugh::laugh::laugh:
Sooooooooo, stupid question because the dealership confused the hell out of me
is
15254700
Engine - Engine and trans mounting - Motor mount
Motor mount Back - 7.0 liter 2006 - 2010
part # Cam gave me is
10349965
Engine - Engine and trans mounting - Mount bracket
Mount bracket Right - 7.0 liter 2006 - 2008
Do I need both the mounting bracket and the motor mount, or just the motor mount?
Confused before i order from Parts Taxi :(
