Sorry to ask silly questions, but I'm out of my comfort zone. So if I ran from manifold to expansion to heater to the line just ahead of the radiator, would that solve the problem of coolant only running through the heater core? Also, if I run from the expansion tank to the heater core, shouldn't any air in the line have been taken care of because of the affect of the tank?
Again, sorry for the basic questions...Just haven't done this sort of thing before. Thanks for your time.
Brent--Slept on this!-- Since you have blocked the 'normal' FE by-pass to work the Electric pump the following which is a rework of your idea should do the job.
1. Dash 6 from top of manifold to top of expansion tank [ this will do double duty as air bleed & heater hot supply- in practice it may need to be enlarged to -8 or even -10 (1/2" or 5/8") to get enough flow/heat in actual heater core, but start small to prevent overheating- make thread fittings in manifold/tank large initially with stepdown AN adapters so you dont have to rework whole system to fit larger fittings later].
2. Dash 8 or 10 from bottom of expansion tank to heater, then same from heater into main radiator return [ you may be able to fit this up front if convenient ].
3. Dont forget the small bleed line reqd from radiator top tank to expansion & the -3 bleeds from rear of manifold if nose down engine mounting.
Steve C.
While the FE head is slightly different in configuration the need for rear bleeds could still be there if a nose down installation.
Other than the air bleeds, the other way air can be purged from these 'spots' is going up an incline that negates the 'nose down' angle or where coolant flow rate is sufficient to move the air.
You also have to look at each situation on its own merits- for a road car it might only occur in traffic & @ slow engine engine speeds where coolant flow is insufficient and the next increase in RPM or slight incline might suffice to 'shift' any air bubble.
A track car @ high power levels can be 'creating air' on a regular basis, so continous purging this by rear bleeds can help.
In the real world, if your pushing coolant out of the expansion tank into the catch tank in sufficient amounts that you regularly have to add coolant to the system then you have a problem & the need for an air bleed system is the first place you should look on these cars.
