Hi All,
I am trying to avoid overheating on my CAV and thought I would reach out for advise.
I am running mech water pump and have drilling small 3mm bleeds into the rear of manifold and behind water pump going back to expansion tank to stop accumulation of air in the heads.
I do not however have a bleed line from the rad back to the expansion tank.....
I have the engine out at the moment and wanted to know what people thought of plumbing in this front to rear bleed line....?
Also I am thinking of an electric water pump......
If anyone has experience with these electric pumps I would be delighted to hear of the way its plumbed in and where and whether its used in tandem with mechanical or in place of..... I am guessing in place of as how would the faster water flow from electric pump flow past the impellor on the mech pump (unless impellor removed...?)
Also did the addition of electric pump require Alternator upgrade as I guess they draw some power and with fans and possible AC running maybe the undercharges....?
I think that's about it for now and delighted to hear the thoughts of those kind enough to provide their experience and thoughts....![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
