Fitting sbf 302 flywheel.
I'm trying to bolt my flywheel onto the crank and I can't find any allignment marks (1971 sbf 302). Am I right in thinking that the bolts are all slightly offsett so you can only put it on in one position ?
Also anybody know where I can get the low style oil filler caps for ally rocker covers.
Paul, The flywheel will only fit one way, but it is VERY important that it is balanced to the engine before you fit it. We make the very low oil cap for Ali Rocker covers, call me if you want, Frank
Neal
Also, be sure to put thread sealer on the bolts as the holes are through tapped into the crank. Otherwise you have an oil leak into the bellhousing.
Thanks guys, the whole rotating assembly was balanced together - this is the first time I have tried to fit the flywheel. The guy that balanced everything for me marked the front pulleys clearly but I couldn't find anything on the flywheel - hence the post. Frank I'll give you a call this week.
