Ford Small Block Pulley Set
More garage sale stuff:
I've got a March Ford SB powder coated aluminum pulley set for sale. Includes crank pulley, alternator, and water pump pulley. Has all bolts, and a spacer which might help out on some installs.
This set is a v belt set and is for a STANDARD length water pump. It will bolt right up to those I'm told. It WILL NOT bolt right up to a shorty water pump, as I have found out. It'd need a lot of spacers under the water pump pulley to do that and that would defeat the purpose.
Bolt on a motor, in good shape, some bolt marks around the holes but you won't see them once covered up with bolts.
$70 shipped to you anywhere in the US. Outside of the US it'll be more expensive due to shipping.
Ron
