Anyone on here got any experience with getting custom steel forgings made? any recommendations or suggestions welcome?
Thanks...
Thanks...
Hi Andy, Ideally I am looking for something with reasonably tight tolerances, but plan B might be a bit more rough and ready, and do some more final machining.Hi Brian,
what sort of forging are you after. Something simple, that could be manufactured in a traditional blacksmith's forge, or something, with tight tolerances and a complex shape?
Andy
Thanks Scott, I will look them up.try Ellis Hubbard in Cleves Ohio.
Thanks James, Yes I have spoken to them, but they are not interested in low volume.WH Tildesley Ltd - Closed Die / Impression Die Drop Forging Specialist - ©2026 W.H.Tildesley Ltd | The UK's Oldest Drop Forging Manufacturer
WH Tildesley Ltd is a UK based drop forging company specialising in the manufacture of drop forgings up to 75kg. We can produce drop forged and machined components from 25 grams up to 75 kilograms in a wide range of materials. Closed die and impression die forging specialist.www.whtildesley.com
Thanks Brian, but looking at their website it looks like they only do aluminium and Titanium.Hello Brian. I have not used these people, but was involved in a conversation at the PRI show and they were highly recommended.
History – Performance Forge, Inc.
www.performance-forge.com
Regards Brian
Sorry Skip, only just seen your post, I will keep you in mind next time. Thanks for replying.....What kind of forgings are you looking for? Do you have a drawing? What material and heat treatment? My shop does buy and machine forgings. Would have to see more information before I can determine if in our wheelhouse. www.diecraftmachine.com
