FS USA G50/50-2 for sale
Available for sale is a G50-50/2 short tail (1989 Turbo box)
Transaxle was modified by California Motor Sport (receipt on request)
Complete tear down and rebuild
New Syncro’s
Billet side covers,
Billet shift forks 1-2 and 3-4
Wavetrac locking diff
Internal spray bar
My cost over 13k.
Also included in the package
KEP adaptor late to mount to LS7 (one stud needs rethreading)
Kep stage 2 240mm disc and pressure plate with throw out bearing (About 750 miles of use)
Release fork with all associated hardware,
MPL clutch slave cylinder (reduces pedal effort by 30% according to manufacture)
Rear mounted cable shift adaptor
Billet shifter from California Motor sports
Aluminum shift stand (to raise shifter if you want)
Shift cables, (these fit my car, you may or may not be able to use them)
Rear trans mount (supplied from Ultima UK)
High torque starter
Axles (supplied from Ultima UK)
Trans pump for spray bar and filter for pump.
If I find anything else on the shelf that could be used it will be shipped to you, I think I have a spare slave cylinder, pilot bearing and clutch alignment tool floating around
There is no mounting bolts for adaptor plate to engine, I had to use to mount new transaxle. Should be readily available from any autoparts or from Kennedy Engineerinhg.
Firm price for all above is 13k plus shipping. It would cost you more than 17k to order all this separately
It is located on Long Island , NY Ill deliver up to 150 miles free.
http://www.gt40s.com/forum/attachment.php?attachmentid=86046&stc=1&d=1493749880
http://www.gt40s.com/forum/attachment.php?attachmentid=86045&stc=1&d=1493749823
http://www.gt40s.com/forum/attachment.php?attachmentid=86047&stc=1&d=1493750023
sorry for the delay,
From Gbox web site:
Gear ratios:
1st gear: 3.154
2nd gear: 1.789
3rd gear: 1.269
4th gear: 0.967
5th gear: 0.756
Ring and pinion: 3.44
Nice gearbox, CMS does great work. I was looking at this exact set-up several months ago to replace a ZF 5 but ended up going a completely different route. Good luck with the sale.
