GT40 Nose
Ford GT Mark I/II Nose - Complete front body panel w/o hood insert. This is not a cheap kit car outer skin.
Full bonded inner paneling and duct work for brake cooling and air inlets to interior, with head/driving light boxes and covers. Tilt/Hinge plates installed to mount on pivot pins/studs that can be adapted to frontmost corners of the monocoque's nose subframe (eliminates having to slide nose forward off of mount pins and set on ground - with monocoque set to 4 to 4 1/2 inch ground clearance nose will pivot forward without hitting the ground if a retainer cable is used).
No visible body damage to fiberglass but will require repaint.
Newer CIBIE headlights w/bulbs installed - Lucas signal indicators mounted, with full lighting harness.
Driving lights (inexpensive aftermarket units) may have to be adjusted and/or remounted
Head and driving light Lexan covers fitted and mounted (one is cracked but will make a good pattern)
Center radiator cooling air inlet has mesh screen installed, might not be included, but if it is will have to be flattened as it's a bit wavy now.
Local pick-up, or will deliver within 500 miles of Detroit for $450 plus expenses, or you can arrange your own shipping.
Motivated to sell, if it brings $4,500, I will include 2 original Marchal GT40 driving lights that are complete with full housings, lenses, bulbs, wiring and mountings, with their original boxes.
Please send any inquiries via Private Message as I DO NOT regularly monitor this site. If you post a question or inquiry here I may not see it before an extended amount of time has passed. Thanks.
Stock Photos of Lights
