I was sent these notes on springs which I used as a starting point for what I now have on my car and am very happy with.
Front: 7” 400 lbs. Main spring, 60mm diameter
3.85” 250/625 lbs. Progressive rate tender spring
Rear: 6” 500 lbs. Main spring, 60mm diameter
4.6” 360/850 lbs. Progressive rate tender spring
Notes:
1. Available from Eibach on 01455 286526, try Rob Hodgson in Technical Sales
2. A spacer is required between the two springs, Eibach will supply these as well.
3. It was recommended mounting the tender spring at the top as this helps stop the spacer catching on the body of the damper.
4. Lengths shown are for the Koni damper, you might need to adjust the main spring length to suit if you are running other makes of damper.
