GTD For Sale
My GTD40 currently registered as 6 GTD Price is for sale at £45,000. The car cost me £30,000 2 years ago and has since had a further £37,000 spent on it within the past two years (full backup available).
Summary details of the car are given below:
Background of Car
- Built in 1999 by Keith Baker (has built many cars including a number of race Ultimas) as a fast road and occasional track day car.
- Acquired in December 2001 for £30,000 by me and then subject to a complete rebuild including engine and transmission to make car competitive for circuit and hillclimb work, as well as ensuring remains tractable enough to drive on the road.
- All development work carried out by Wealden Engineering (built the Yellow Peril and Andrew Fordyce’s car amongst others; mentioned in the book “GT40” by Trevor Legate as builder of highest quality GTDs); Dave Milam of SD Racing Services for the engine build; Mach I Transmissions for the gearbox.
Engine
- Current engine is brand new and built by Dave Milam of SD Racing Services.
- Engine has been fully balanced (previous crate engine completely out of balance)
- Output approx. 420 BHP; can be verified on dyno
- Block GT40 SVO 2 bolt main with valve train girdle
- Heads: Edelbrock Victor Junior aluminium heads
- Rods: Eagle H-Beam rods
- Compression ratio: 10.25:1
- Cam: Comp Cams Solid lifter cam with gross lift of 0.570
- Crank: Forged steel crankshaft
- Pistons Keith Black Hyper Utechtic
- Induction: Holley 750 Double Pumper (competition); Holley 650 (road)
- Sump: Canton Racing baffled sump
Suspension
- Shock Absorbers: Koni externally adjustable with separate adjustment for bump and rebound possible
- Springs: Eibach progressive
- Front: Nylon bushes
- Rear: Fully rose joined (Aurora rose joints as used in F1)
Transmission etc
- Gear mechanism: Rod gear change custom built by Wealden Engineering
- Clutch: AP Racing
- Transmission: Renault 21 Turbo rebuilt by Mach 1 Transmissions and a Quaife limited slip differential added
Exhaust System
- Full crossover system (“bundle of snakes”)
- Coated
- Repackable silencers added by Wealden Engineering
Brakes
- Hi Spec 6-pot callipers at the front with carbon fibre race pads and 335mm vented grooved discs
- Hi Spec 4-pot callipers at the rear with carbon fibre race pads and 315mm vented grooved discs
Wheels and Tyres
- Image BRM 17” split rims
- Pirelli P Zeros: 235 at front; 335 at rear
- Replica spinners by Image
Cooling
- Pace aluminium race radiator (light weight and highly efficient)
- Deep front nostril modification by Wealden Engineering (but with MK I look nose)
Other:
- Tilton race pedal setup
- Dual Mallory high pressure fuel pumps (to cope with high power engine)
- Engine start button (illuminated)
- Original removable steering wheel by Moto Lita with replica “Ford GT” badge
- Mount for camcorder in cockpit
- Original bullet style wing mirrors
- Replica GT40 seats by Wealden Engineering (not GTD seats)
- High capacity battery
- Mounting brackets for rear clip adjusted to attach to chassis rather than glass fibre
- Electronic drive speedo (allows recalibration with different wheels and tyres)
Competition
- The car is fully compliant with current MSA sprint and hillclimb requirements
- Luke 6-point harnesses (driver and passenger)
- Rollover bracing struts (added protection in event of a rollover)
- Latest fire extinguisher system with electronic activation and self-test facility
- Timing struts and mounts
- Towing eyes and mounts front and rear
- Secure battery box
- Electrical cutout switches inside and out
Please note that the cherished registration is available as part of a separate transaction. However, the car will be re-registered with a period plate for no additional cost.
If you are interested, you can email me at: [email protected]
Martin...I'm sure you realise that even when you sell your car, you are still expected to attend the paddock in your shiny silver romper suit!! Seriously, I hope that this will not prevent you from coming out to play this season.Whoever purchases your car will get themselves a little gem.
Martin,
can you give me the specs on your wheels - backspacing,
17x??, etc. Are the rear arches flared a little, or does
the backspacing allow the 335s to fit with minimal
hassle? Interested in selling it minus engine? /ubbthreads/images/graemlins/smile.gif
Seriously, I think for the price, it's a great deal
for someone in the UK. This car is well sorted and has
lots o' goodies. And it's only been raced gently /ubbthreads/images/graemlins/wink.gif
Ian,
The front tyres are 235 45 ZR 17
The rear tyres are 335 35 ZR 17
The arches are not gulf flares - the wheel offsets allow using such big tyres without having to adjust the arches.
As for selling the car without engine, I would prefer to sell as a complete package but would consider this option. Price without engine is £40,000.
Martin
Martin,
One more question if I may: what are the offsets and
the actual wheel dimensions? I wasn't serious about
selling it minus engine - which is what I would have
to do if I wanted it shipped to the US. That would
make it very expensive.
Thanks again,
Ian,
I realised you weren't serious about buying without the engine (the wink gave it away!) but this was an option I had considered if people wanted to do a deal on this basis based in Europe - hence the post to let anyone else know.
Regarding the offsets, I do not have this info to hand so will have to get back to you on that.
Cheers, Martin
Martin,
Why on earth would you want to sell such a superb car?
J.P
I hope you're not losing the faith dear man!
OK well thanks anyway. I hope all is well with you. It must be very hard to part with such a fine car. I hope in time you can do another one. We all learn so much from the first one that a second is a dream many must have.
