chip
the brakes are as follows: the rotors are brembo cross drilled 13" from a mustang cobra(all arround). i found them in canada for about $93 each. the calipers i found used from a Diable that was totaled. they are brembo 4 piston front and rear. the fronts are larger. i paid $250 for each. the master cylinders and pedals are wilwood. they were about $150 for brake and clutch set up floor mounted.
you can buy the rotors from the same place as i did, my friend just bought 6 piston calipers from wilwood for $250 each)4 pistons are $122) and i made my own mounting brackets so you can do the same and you are done. i'll list the parts tomorrow with names and addresses and #'s if you want to call and order.
cheers
luis
