Could anyone recommend a good guide or preferably an instruction video (I.e. YouTube) demonstrating the disassembly, cleaning, reassembly and possibly adjustment of a Holley 600 cfm 4 barrel Carb.
If you plan to disassemble a carburetor, it should be done with the carburetor removed from the intake manifold and placed on a clean workbench. To make the carb more stable, place it on a stand that supports the carb by its baseplate-to-manifold mounting holes. This also makes the disassembly...
Check the Holley List number which is on the choke tower on top of the carb. Check against the Holley List number guide. It will tell you the part number of the Rebuild or Trick Kit for your carb. These come with the blue reusable gaskets which are a lot better than the paper ones which are a royal pain to scrape off. The list also gives the data for the jets etc.
Holley list Numbers here
