Fran:
Is the dash opening the same size as for the Classic gauges? I suspect different pickups would be required, but the wiring harness would otherwise be the same?
They sure look nice. The 270 degree arc of the small gauges adds to the readability.
Will a set of gauges be available from you for those that want to switch over from the Classic gauges?
Is the design of the speedo pick up the same, or will it get its signal from some other source?
Chuck
