Thank you for posting David Vizard's video. He lived here in Tucson at one time; I regret never having met him then.David Vizard Youtube video about Ford 302 block strength.
Mentioned.did they test a Mexican 302???
I probably would have if I had gone the nitromethane route.Neil might Doc. He may have been into drag racing
I recall that Repco did something like that with the Buick/olds/Rover V8 they developed for F1I'm surprised they don't do a bottom end arrangement like the way BMW do it. all the caps and girdle as one piece. given all the effort to machine and make the caps fit, i would have thought it would have been just as easy to join the lot together as one unit and pick up the pan rail as well.
BMW ///M3 S65 Bottom end. the S85 is the same but with 2 more rods.
a quick google.....
from here
‘RB620’ V8: Building The 1966 World F1 Champion Engine…by Rodway Wolfe and Mark Bisset | primotipo...
I think this was possible as the Olds block looks to have a deeper skirt than the Windsor. The Windsor block finishes about 1/8" below the crank cap split line. So if you were making a girdle it would need to be a significant casting.
Mike, so on this engine with 3 main bearing crank you has 1-2 4-3 ignition order?This is what we used to do on Imp 998cc race engines. I used to make ally blocks to go between the steel plate and the main caps. Tuftrided the standard 3 bearing crank and stress relieved and shot peened the standard rods plus forged race pistons. Revved to 10,000rpm and 120+hp from 998cc back in the early 1970s. Not bad for a 2 valve per cylinder engine.
