The RCR-40 MK1 arrived in Australia a few weeks ago. Working on it in my spare time with the help of my brother Craig.
The body, chassis & parts look absolutely fantastic.
It will be road registered in QLD initally, but then used as a track car.
Specs:
Kit: RCR-40 MK1 Deluxe Plus kit with following RCR options: 6 point cage, sway bars, 17" wheels, Double Adjustable Shocks, +2" Suspension & Guards, Gurney Bubble.
Street Engine: 2002 AUIII Ford 5L(302w). Tickford version with 220kw(GTP Heads, Yella Terra Roller Rockers, Oil Cooler, Hand Built etc)
Race Engine: Keith Craft 302w stroked to 363.5, dart 4 bolt block, solid roller cam, AFR 205(ported) heads, zero balanced. Engine has been test dyno'd with 581.4HP@7100rpm, 508 lb/ft. Will be fitted with TWM Throttle Bodies & Autronic SM4 ecu and will be producing over 600HP after tuning.
Gearbox: Porsche G50/01 to start with.
Brakes: Standard RCR - 6 piston fronts, 4 piston rears, 2 piece 11.75" rotors.
Wheels/Tyres: 17" BRM with Sumitomo tyres for the street(supplied with kit by RCR). For track 17" BRM with race rubber.
Paint Colour: Red with twin white stripes.
Interior: RCR seats & carpet, vinyl covered dash, RCR instruments, Lucas switches
Specs:
