Has any company made a turbo manifold for a domestic V8 similar to the one designed for the new BMW S63 motors (found the X5 M, X6 M, new M5 models)?
Would such a rig even fit under the glass of an SL-C? Would the cost to duplicate be worth the performance?
BMW M Head of Engine Development explains the engine and cross bank exhaust manifold in detail here.
In the future, a new direct injection Coyote motor or the up-coming Gen V GM small block would make cool domestic candidates for such a select procedure...
Here's a brief description:
Are are some pictures:
Special features of the M V-8 is a pulse-tuned exhaust manifold and two low-mass twin-scroll turbochargers positioned together with the catalytic converters in the ‘V’ section between the two banks of cylinders. By reversing the flow of gases through the engine from traditional arrangements, the intake and exhaust ducts are shortened and widened. The result is that pressure losses on the exhaust side are minimized.
This configuration, known as Cylinder-bank Comprehensive Manifold (CCM), offers quick turbo spooling, a linear build-up of engine power, and a broad, consistent torque curve by feeding each of the twin turbochargers with a ‘charge pulse’ at approximately every 90 degrees of crankshaft rotation, rather than the more traditional ‘irregular schedule’ of charging.
