Would using the frame and transaxle to mount a radiator be a bad idea, assuming the transaxle and engine is solid mounted to the frame?
I'm assuming the frame won't move and since the driveline is solid bolted to the frame it also can't go anywhere, so I think as long as it's rubber mounted at the transaxle mount it should be okay?
It's obviously not ideal from a mounting perspective, but it does provide the best cooling and packing setup.
