Pedal Pads
Hello,
If you are describing the little rubber push through buttons I bought replacement from a good hardware store.
They are available in various sizes.
They are difficult to pull through the holes in the pedals but if you remove the pedal and work in a vice you can grease the hole in the pedal and pull the rubber button through until it seats properly.
Eric
We do not have pedal rubbers for the CAV GT.
Some of the older cars have push through rubber buttons that is available from most hardware stores, as Eric mentioned. You should be able to upgrade your pedals to the same. Later cars has an "anti slip" coating applied to the pedals with no rubber buttons or covers.
Johann Keyser
CAV-US
www.cav-america.com
www.motomotivo.com
Mike:
Cheapest and smallest pads I have found are off MG midget. I think i paid $5.00 for three.
I simply cut my metal pads to size and they fit over nicely.
Available in most of the catalogs.
Phil
Ha Mike,
Do they look like these, they are the original ones from my GTD! that I didn't use
Bob
Pat
Bob, those look exactly like the ones from a CAV. Any idea what application they are originally from? I assume GTD sourced the part from some standard application.
Another option is to simply apply some marine non-skid tape.
I believe these are what I'm looking for. Can I order these from TBD source or are you willing to sell these? If so, let me know.
Thanks,
Mike Kolesar
