pictures of electrical wiring
Rune
I have all the looms for the electrical wiring and a diagram from JWA , but I hoped that someone out there have some pictures from the installation of the cables . If can install the cable bundles correct , it is easier to figure out where the cables have to go. I was promised a list that compare numbers and wire colors that will help me some. It is a MK I .
Regards Rune
Hi Rune,
If the wiring diagram you have is the one that I think it is, it's a hand-drawn copy of the Mk.II wiring diagram from the SAE Papers. Also in the SAE Papers is a photograph of a mock-up of the wiring installation which will give you a rough idea of where everything goes. Everything from the dashboard area to the engine bay pretty much runs down the left side of the cockpit as do the capillaries for the temperature and pressure gauges.
Send me a PM as I can supply you with a lot more info.
Brian Stewart
I'm guessing this is the one you mean Graham.
