Chris Kouba
On a 302 with a V belt rotation water pump, what direction does coolant flow through the two 5/8" ports?
I know the top one is the bypass inlet, which I presume flows water INTO the water pump, so that one goes in.
Does the other (lower) one draw coolant in or push it out?
Another member was kind enough to post this diagram, which makes sense to me:
However, a different set up was recommended to me which has that lower port connected (5/8" hose) to the bottom of a high-mounted expansion tank with a 3/8" bleed line from the rad connected to the top of it. The expansion tank has a pressure cap which feeds an overflow.
This second system is up and running successfully on multiple cars, I just don't understand the flow of coolant and how it's doing its purging of air.
Thoughts?
Thanks in advance,
Chris
Thoughts?
Thanks in advance,
Chris
