ABS is over-rated =)
Flat-spot ONE tire on four separate occasions and then tell me your opinion. If it's "You haven't mastered threshold braking," my answer will be "That's right. I'm not that good and never will be. I want ABS."
JR
They have not yet delivered a transaxle to anyone, to the best of my knowledge. I was supposed to get one of their first three sequential boxes, which were supposedly the first boxes of any type they were going to make. That was last June. No contact from them since August. I don't want to use the word vaporware, but I couldn't wait indefinitely.
Maybe next year we'll all be singing a different tune.
JR
JR,
Tommy Archer knows Vipers for sure. The ABS debate will rage on. There must be some value in them. Even Vipers from 2001 on had them....
Here are the full specs on the 442 ITB motor from Thomson: 4.130" Bore x 4.125" Stroke. 11.8:1 Compression Ratio. Cam specs .669/.685 lift, 251/262 duration @.050, 113/118 deg lobe separation.
Last pull peak power 739.9 @6500 peak torque 652.1 @5400
The original numbers in my first post were Brian going by memory on the phone, where he transposed a few digits. The ones above are from the dyno printout and the build sheet.
JR
WOW! Too cool!
