Make sure the swirl tank is full before you run the high pressure pump. I installed a toggle switch that allows me to run the lift pump without running the high pressure pump. I don't know if the swirl pot drains or not, but if the car has been sitting a while, I run the lift pump for a little bit before starting the engine to make sure there's fuel in the swirl pot.
