Chris,
A great source of composite fabrication is the home built airplane community. I built a Long-Ez which is fiberglass/epoxy over foam core. See if there is anyone near you building a composite plane an volunteer to help them do a layup. It is not that hard to learn and there are a lot of tips to make it easier. They will know the local sources or epoxy, glass, tools, filler, etc.
There are some expoxies that you can get from local boat stores and I can provide info on that if needed.
Hope this helps.
Steve Rothert
Hope this helps.
Steve Rothert
