I’m just now getting my car back up and running after an extended hiatus to correct a number of things that needed correction. The cooling system required a major upgrade, as it was never going to function efficiently the way it was configured by the original owner/builder. There were so many things wrong with it, I’d have to write a book to cover it all.
At this point, the system has been correctly configured front to back and looks to be functioning flawlessly. The only thing that concerns me now, is that the cooling fan motors are extremely hot to the touch after only a few minutes of run time. I’ve never noticed that to be the case before. Do these fan motors normally run hot to the touch? Btw, these fans have very low hours on them, like everything else on the car, so service life wear is not a factor.
I should add, the wiring on this car is also a big mystery. Everything works, but the wiring doesn’t seem to follow recognizable color code and gauge standards of a typical commercial wire harness such as Painless or Ron Francis. I have no schematic, and all of the wiring is encased in plastic looms, so any electrical troubleshooting will be a hugh PITA.
