Hey,
I was in the process of putting the drive train in my car and had a thought three weeks ago. What about making the engine and transaxle a stress member. Since my car is a space frame and not a mono it does not even look like an original with the tubing in the rear. So by putting in front and rear motor plates with some stabilizers mounted to the stock motor mounts will secure the drive train to the chassis. Will also make a small cage that mounts to the transaxle that has the suspension pickups on it. I was also considering doing a pushrod setup, but did not want to change the look of the exhaust so I am considering a pull rod setup (Lower CG). One other good thing is I have some rear uprights off a 1999 Reynard Indy Car that are already a 6 pin setup and the 8 piston Brembo’s I have bolt right on. Below is some renderings I put together.
And a couple pictures of the rear uprights.
Here is a picture of a plastic engine with the hewland in the back of the car. Also the tires and wheels I plan on putting on the car.
