Scott, You do some seriously nice fiberglass work! I know the problems involved, I'm impressed!
Back about a hundred years, I was a partner in a custom car building shop. We specialized in show cars, mostly corvettes. Behind the shop we had an old sailboat hull. We used it to lay up all kinds of custom panels. It had about any kind of compound curve or radius that you could want for a custom part. Wax it up and lay your panel. The parts were really great quality. Mind you, this was before you could buy so many parts in the retail market. Looking at your work Scott reminds me of those days.
Thanks for bringing back some fond memories.
With the cut lines you taped off on the nose, are you picturing the area between the two long lines would be dropped lower, giving it more of an LMP pontoon fender look?
I think that we are just on the same wavelength Scott. I was the concept guy in our shop. There is always somebody better at the grunt work, but they always cane to me for the concept. That, I think, is the most important ingredient in a recipe that knocks your socks off in the end. Hang in there. I think you have a great concept there.
Here's a thought....what about a series of concave, wide louvers ascending to the apex of the triangular cutout.....like the rocker louvers on a Saleen S7. They could be fabricated off the car and bonded in place, leaving only the bond point to blend and thus simplify the bodywork. Somebody smarter than me (Scott) could even figure out how to angle them to direct air into, over, or around the body as desired.
The first cut is always the hardest!
Split PVC pipe can be used as a mold with one layer of 1-1/2 Oz. Matt and should shape fairly easily (slit where necessary) for the radii of your blends. Have fun!
