shifter cables needed --- gt40 mkII
trying to remove "master shift" electronic digital shifting... and superformance doesn't have any cables in stock, please call if you can help, 352 871 8861 thanks
Did you try Dennis? You could also have one made up custom from a variety of sources.
Mike is sending you off in the right direction. Dennis Olthoff may be able to lay his hands on a 'used' on off of 2124. His number is 704 647 9924 and usually best to try after 8;15 am. Grady
If you know what you need, such as a sample or even just a bill of materials, then call:
They can make ANYTHING and is the highest quality I have seen when it comes to push/pull control cables.
Another benefit is this. When I was building my SLC I wanted to change the length of one of the shifter cables. I sent it to them and they shortened it for a third of the cost of a new one AND saved my information with a part number. When my throttle (cable also from them) got burned by the exhaust they were able to just look it up and make one with a phone call and ship it to me overnight. I had it on the car in three days. Perfect fit exactly the same part.
I can't recommend them more adamantly.
California Push-Pull Inc. Cable Specialists Based in Chico, Ca.
^ yep.
Had a set made in Europe from a very highly reputable firm, and didn't love them. Had the above make a cable for me, ended up being cheaper and a lot better - less slop, less friction.
