M Mark Clapp Nov 19, 2002 #1 What are the dimensions of the side window cut outs that flip out for extra cockpit venting? I know its a "leaning" rectangle so side lengths will do the trick.
J Nov 19, 2002 #2 Mark, Mine are 7.25 wide X 7.5 long. I'm sure eevryone will have a different answer but since these are mine I'm sure they are right John
M Mark Clapp Nov 26, 2002 #4 Thanks John. I am working on affordable replacement windows. Does anyone else agree with the 7.5" x 7.25" dimensions for the cut-outs?
J Jim Nov 26, 2002 #5 The cutout data I have from #1008 Mark I is as follows: lower opening is 218.2mm wide upper opening is 219.mm wide top to bottom is 201.2mm at front top to bottom is 201.5mm at rear it is about 71mm forward of the rear edge of the side window. Give me your fax number and I can send you some sketches
Ron Earp Admin Nov 26, 2002 #6 Looks to me like they wanted them square and got it slightly off. Wouldn't suprise me with what the cars were intended to do and estimated lifetime. R
