I'm guessing that the side windows will be common with the other manufacturers, but can someone confirm that they can supply windows that will fit (I am aware that they are generally supplied slightly oversize)
I know Roy Snook used to do them.
As he is not far from me - if he needs to check on size I can have a drive over so he can check his window against my car
That said I do not know if he also does the hardware for the opening windows
Ian,
thanks, I do need the small window fittings too, mine are pretty cracked and beaten about now
I'm sure someone will know whether they are the same size as GTD /Tornado, I can always make and send them a template to verify.
