Source for adapter pins
Does anyone know where the pins from Ray Christopher's pin drive adapters come from? When I purchased the adapters we thought that the rotor hats (bells) should be sandwiched between the adapter and the hub. Having second thoughts now regards to maintenance and would like to consider putting the rotor outboard of the whole assembly. But this would require longer pins as the hat thickness will reduce the length of pin engagement into the wheel. It would be ideal if I were able to purhcase pins that protruded from the adapter an additional 1/4 of an inch or so.
Many Thanks
Brian
I have Ray Christopher's knock on hubs too. I also had an issue with the length of the pin. Are you talking front or rear or both??
Ray supplied me a second set of pins becuase the first were too short. The 12 I have spare are 1 5/8", what length do you need?
