Hi Eric,
I dont claim to be an expert on spring rates, etc, but I do have a reasonable understanding of what is required, there are many people on this site , who will be able to go into a lot more detail, than I can, and hopefully they will contribute to this thread..........come on guys help Eric..........
Yes getting the wrong spring rates will affect the ride height of your car, If you keep the same Spax units, and want to make your suspension stiffer, then keep the same lenght spring, but use a stiffer spring. If you measure the diameter of the springs, and count the coils, with this information, a good spring supplier, will be able to recomend a stiffer spring for you
If you use new shocks, stick to themanufactures recomended spring lenght, as far as choice of spring rates goes, speak to the supplier, tell them what you have on your car, and they should be able to recomend the correct springs for you
You say your suspension is ok apart from when you drive with more speed, is it when you are cornering , that your suspension is too soft, if so , then if you stiffen your sway bar, this will reduce body roll, and give a stiffer ride, If your suspension is too soft all the time then harder springs are what you will need
I hope this helps,
mick
