Superformance MK1 Rear A-arm support collar
I have 4 lower A-arm support collars water jet cut from 1/4" 4130 moly and powder coated. Superformance MK1's did not come with these as the original cars had. They are a must if you track or aggressively drive your car. they are $100.00 + shipping from Socal.
Hi Rick, do you need to use longer bolts to use these brackets? I'd put me down for one. Thanks
Rick,
Put me down for one. Just let me know when and where. I can meet you since I'm in the area.
No, You can use the same bolts just discard the large washers on the a-arm bolts.
I replaced my a-arm bolts with new grade 8 because they were slightly bent. It's probably a good idea to replace them anyway.
Someone decided not to take the support so there is one left for whoever comes first. PM me if interested. Thanks!
