Tachometer calibration needed
I installed a SBF 347 in my old 1988 Lotus Esprit a few years ago (I did take the Lotus engine out first...). The conversion took a while to say the least.
The car runs well, pretty much as planned/expected. Ignition and fueling is by way of an 8 stack downdraft system using FAST 2.0 ECU, FAST duel sync distributor and FAST E6 CD ignition box. I'm ironing out a few details to get the car finally "completed." One of these details is that the Lotus tachometer reads exactly twice as fast as it should (no, that's not 8,000 rpm.....). I'm pretty sure this is because the Lotus tachometer was calibrated for a 4 cylinder engine...while the tach signal wire out of the E6 ignition box is delivering an 8 cylinder signal. In other words, twice as many voltage pulses per XX rotations. The Lotus tachometer is the standard VDO 80's tachometer.
I'm wondering what my best options are....? Get a VDO tachometer from a later V8 Esprit (2004 or later)? Somehow adapt/calibrate the tach signal to cut the signal in half? I don't believe there's any adjustment or calibration function built into the ignition box or ECU.
Anyone have any experience with this kind of thing before?
Thanks in advance.
Neil
Thanks in advance.
You could use a flip-flop to divide the pulse rate in half. Old versions of CMOS logic will work on 12 volts.
