Turn signal indicator light
My car has a three position dash mounted toggle switch, but no indicator light, which I need to add. The system has a two pin flasher, so I bought 12v zener diodes and indicator light to wire in.
Can anyone provide a simple wire diagram showing how the diodes and indicator light need to be wired into the system?
B5071B53-C2E7-4001-A9C6-B6F124A0D26C.jpeg51D6867E-9C64-414C-B376-D531B942FE80.jpeg46C2346C-19A0-4125-8A7C-57F550612487.jpeg
That's a fine suggestion Bill, but I don't need or want two indicator lights on my panel. I just need one light to alert me that I've forgotten to return the switch to the off position like grandpa driving his Buick. Thx
Bill Kearley
OR, I have a two buttons on my steering wheel that I use as grounding switches, One left and one right.. I hold my thumb on a switch and hold before a turn is made.
Ian, something like that could be a strong candidate if I can find one that appropriately suits my panel. I shall commence a search.
Bill, I love that idea from a functional perspective, but how are they wired? Is your wheel removable? Does it have a special slip ring (rotary contact) hub design? I’d still want a light on the panel to let me know my flasher hasn’t quit.
Thanks for the ideas gentlemen, clearly there’s always another way to skin that cat.
Bill Kearley
Hi Michael
I have two indicators on the dash L/R and am using a coil cord at the moment. My wheel is removable and I plan on making a slipring to work and get rid of the cord. Each side is activated by grounding a specific side, L/R. I simply ran a ground wire from each side and using a dedicated bulb to avoid any feedback. I am still working on slipring design that will look pretty.
That makes sense Bill, thanks for the description. I guess once you commit to a turn, you release the button. Any problems so far with cancelling the signals early in tight turns and heavy traffic?
Bill Kearley
Yes , once your into a turn there should be no harm in lifting your thumb. If you have to lift your hand for a second just reset your thumb so to speak.
So, to close out this thread, I decided the best course of action was to swap out the two pin flasher for a heavy duty Hella three pin flasher.
I had to re-pin the flasher connector to match the new flasher and run the third wire to the indicator light.
It was much more of a pita to install the indicator light because of the tight confines behind the panel, but now I have it exactly how I want it. It flashes brightly when toggled to either side, so I shouldn’t embarrass myself out on the road.
Cheers gents…:cool:
