I’m at the stage of roughing in a wiring harness. All toggle switches on dash and separate tell-tale lights.
I have a 3 position switch (off/on/on) I want to use for the dip and bright headlights.
I want to keep each circuit simple.
So do I:
From the 3 way switch position one, wire to a relay and then the dip headlights. Take output from switch also to green tell-tale light.
From the 3 way switch position two, wire to another relay and then the bright headlights. Take output from switch also to blue tell-tale light.
I’m thinking to wire the instruments through a seperate toggle switch so I can have them on without the headlights, if that might be desired.
Where do I take the feed for the taillights from? A feed from both the dip headlights relay and the bright headlights relay? So they are on no matter which headlights are on.
A cheat might be to wire them from the instruments toggle switch?
Regards
Fred W B
So do I:
Regards
Fred W B
