B Bill D Feb 7, 2009 #1 I need to replace my Ford Racing mini starter. Should I risk going with another one which is in stock at Summit and Jegs. CSR and Powermaster aren't stocked and have ship dates 3-4 weeks. Setup: ZF transaxle 157 tooth flywheel 302W
Randy V Moderator-Admin Staff member Admin Lifetime Supporter Feb 7, 2009 #2 I just got one off of a v6 car in the bone yard and it worked perfectly.. What happens when you bench test it (clamped in a vice) ???
B Bill D Feb 7, 2009 #3 Randy It spins and makes grinding noises. But the pinion gear doesn't move forward
D Dean Lampe Feb 7, 2009 #4 Where did it come from? If it is from Jegs or Summit they will likely exchange it. Maybe.
B Bill D Feb 7, 2009 #5 Dean I bought it from Jeg's 2 years ago. However, I just used it for the first time in June.
D Dean Lampe Feb 8, 2009 #6 Jegs has a 2 year return policy with something like a 20% restock. I don't know if they will do anything for you but it might be worth a call.
