D Dean Lampe Nov 10, 2006 #1 I bought a ZF tranny and it doesn't come with a bell housing. Would any of you have one laying around?
B Bill D Nov 10, 2006 #2 Contact Kennedy Engineering. They are the ones that make the bellhousing to mate the ZF to the Ford engine
Fran Hall RCR Nov 10, 2006 #3 Make sure which ever one you buy takes the flywheel/flexplate you plan on using 164 or 157 tooth....as different manufacturers offer either Last edited: Nov 10, 2006
Ron Earp Admin Nov 11, 2006 #4 And if you are ordering from KED, order early and call often to check on your order.......
D Dean Lampe Nov 12, 2006 #9 KEP can do it for $350. That seems reasonable. They don't have it on the shelf so that will probably mean a few weeks wait. Are they a 157 or a 164 tooth kit?
J Jim Rosenthal Supporter Nov 15, 2006 #11 ERA will also sell one of theirs. It is more than the KEP bellhousing. It also accommodates the larger flywheel, etc.
