Over a month since an update. Shocking.
Although I've not been as busy on the car I've been working steadily at the odds and sods that make up building a kit car. Upside to buying a 'basic' kit is that you get to totally customise how you want the car. Downside is that you get to totally customise how you want the car...
That of course means you have to make all the decisions, source everything and that takes time. That's what you pay for when you splash out on that 'deluxe everything included kit', someone has put the hard work (time) in for you.
Anyway, my wife bought me a air/hydraulic riveter for Christmas which will come in handy and so in the last month I've:
- Ordered the engine to gearbox adapter plate (its been cut and is being machined at the moment)
- Ordered the oil filter/cooler take off plate.
- Bought some fuel tank sensors.
- Worked out how I'll run the fuel circuit
- Ordered enough electronic components to build the trial fuel controller.
- Ordered an injector rebuild set (pintle caps, o-rings, seals, micro-filters).
- Ordered a whole load of fiddly bits, gasket paper, hole punches, misc crap etc.
Plus I've been hard at work cleaning up the engine. Starting at the very top and working down. Mostly because the very top will be on show.
Should really have got a better picture before I started but this is the inlet manifold
These are the inlet tracts.
and this is the inlet manifold it stands now
What I'm undecided about is do I polish it or just clean it up and paint it?
The RHS in this picture is about 80% polished, it'll still need a
lot of work.
If I do paint it, what colour should I do it, I was thinking black and polish the fins up? Any comments or other suggestions welcome.
What those pictures don't show is the mess a modern inlet manifold gets in after 90k. EGR, just say eaugh, no thanks :furious:. Foolishly didn't take a picture of the nastyness that was the inside of the manifold before I started but this is the EGR manifold (which bolts onto the inlet manifold)
It should look rather more like this
It's not going back on btw, no EGR for me but I need the manifold as it's also used for the crankcase vent!
I'll take a picture of the inlet manifold throttle valve when I remember, nasty.
