I used 2mm by 13mm stick on closed cell foam strip (from Baines)
I found a belt hole punch was the easiest way to get neat holes for the bolts.
I also stuck the strip on the cover instead of the bulkhead - damn slight easier to work it on the bench than inside the car!
Sealed brillintly - up to then I did get fumes in the cabin
