I am attracted to the graceful curves of the MkI
Being serious for just a moment, I agree completely; the Mk I is by far the more "beautiful" or "pleasing" or "graceful"; the Mk II shows every evidence of a car that was hastily modified to execute a one-time blitz at minimum effort and modification. As the song goes, "evil, wicked, mean and nasty".
Seconding Kevin's caution about wooden blocks, etc. That is 22 or 24 gauge mild steel; you can practically crease it with your thumbnail. Also the black paint on the chassis outside the cabin chips incredibly easily, so either get used to that and keep a can of satin black paint around, or be incredibly careful.
Tow hook advice is important as well; do
not let anyone tow by the front cross bar, it bends easily. And the front suspension bits are hard to reach. And probably at some point you will need to tow.... Pegasus sells this handy item:
https://www.pegasusautoracing.com/p...//www.pegasusautoracing.com/keywordsearch.asp
Along with Grady's advice about a fire system, you also want a electrical cutoff. But then this is true of any hand-built race car, although here you are sitting between two 10 gal gas tanks.
I'm going to take counterpoint on the brake ducting: I don't see why that's needed on a street or non-actual-competition car. Rapid cooling of brake rotors is actually a bad thing since it encourages warping, and the ducts etc. just pipe a lot of grit and grime into that area. Yeah the look cool, but it's another thing you have to fuss with to work on that part of the car, and what's the benefit? Anyone here actually faded the brakes?
Dennis suggested I switch from the supplied brake pad material (BP-10) to H.
Kevin's advice on engine tune (#12 & 14) is also important and correct and not that many people will tell you that: you can always upgrade the motor later, that's a lot easier and cheaper than being pulled from the wreckage and resuscitated at the side of the road after you spin it into a tree.
Since we're way down into maintenance stuff: be careful around the rivnuts; quality control on proper setting and hole quality is not there so it's really easy to spin one. If you want to do yourself a big long-term maintenance favor, every time you remove a sheet metal screw for the first time, replace it with a machine screw and a rivnut or threaded insert. Sheet metal screws in that 22 or 24 gauge mild steel and thin fiberglass are a travesty and were a good idea only from the point of view of the guy throwing it together at the factory.
And regarding workmanship, since you brought up the point, don't expect it to be as good as an SPF Cobra, unless something has really changed since mine was built. I'll stop there since certain people here get a little apoplectic when I deliver that message.
Have your headers ceramic coated; watch out for SPF's price for that. You should be able to have it done locally for <=$500. Heat management in back is an issue (more with an FE of course) so anything that reduces heat storage is good.
