I’ve currently got Rally Design Poly-bushes fitted to my chassis and after recommending them to John Christian, an issue has arisen, specifically around the use of the bushes in the rear suspension. See previous post: http://www.gt40s.com/forum/gt40-tech-chassis-brakes-tires-wheels/35870-poly-bushes.html#post354779
<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com
<st1:City w:st="on">Westfield</st1:City>, however when used in a ’40 there seems to be excessive play after a while. As supplied the inner sleeve is a light push fit into the bush, but when I’ve fitted these before from other manufacturers, they are really tight fit. I’ve measured the Shore hardness of the bushes, which is about 80, so no issues there. <o
></o
<o
></o
On the front suspension, both the inner joints are used in pairs therefore the forces in the bush is halved. However on the rear inner the same bush is used singularly, effectively doubling the load.<o
></o
<o
></o
Also to function as designed, the Poly bushes has to be fully supported (i.e. clamped between 2 plates to prevent the bush deforming) whereas as on the rear top inner mount on a Tornado this is not the case, with the bolt tube coming through the chassis and then welded. <o
></o
<o
></o
So a few recommendations:<o
></o
></o
<o
></o
Hope this all makes sense<o
></o
<o
></o
Regards,<o
></o
Andy<o
></o
<o
<o
<o
- Replace the inner bushes with a rod ends. Adding one to the top link and using a L/H thread makes changing the camber much easier<o
></o
> - Fit a stiffer bush, it may be easiest to replace the current bush with a hard nylon etc.<o
></o
> - Fit a larger inner tube, which would effectively put more pre-load on the current bush, causing it to stiffen <o
></o
> - Use the original specification metalastic bush, however I’d still be concerned about the long term durability of this.<o
></o
> - For the top inner mount on a Tornado, grind back the chassis support tube sufficient to add a larger washer too effectively prevent the bush from deforming. There is sufficient material to grind 3mm off the tube for a washer and not touch the weld.<o
></o
<o
<o
Regards,<o
Andy<o
